tranny problem
curlygrooms
arkansas
got the 351 in and running great,but when i went to back out of the garage,had to give it a lot of gas just to barely get it to roll.in drive,it won't shift out of 1st gear.i did nothing to the trans except unbolt,rebolt it and change the trans filter.checked everything i could think of.any one have an idea of what i might have missed????
C
curlygrooms
arkansas
Is the 351 the original motor , what flex plate did u use?
18901[/snapback]
pulled out the original 90 model 302,replaced it with 95 model 351 w.used orignal 302 flex plate
BLADE262US
Michigan
What tranny do you have ? If its an E4OD make sure all the electrical conections are plugged in . Also try to actually shift into 1st gear not just drive . An E4OD will move without the computer if shifted directly into 1st or 2nd gear but if you put it into drive it will slip like **** . Also if you have an AOD then the cable that runs to the throttle linkage from the tranny must be adjusted correctly because the pull on this cable is how the tranny shifts . If you have a C6 then something is way messed up . :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
C
curlygrooms
arkansas
18906[/snapback]
thanks,tranny is a 4speeed auto w/overdrive,will check the cable tomorrow.the extra width of the 351 may have screwed up the pull.a thousand thank yous.let you know how it turns out.
79bigbronco
Calgary, Alberta, Canada
I hope that the cable is the problem. I had a similar problem on a 61 comet that I installed a 302/ aod, we used a 351 flex plate, which caused an 1/8" difference in end play to the trans. pump, which caused it to crater said pump. vehicle ran great, backed it out of shop,drove fine , let it warm up , wouldn't move, trashed 2 tranys, before we found the prob. hope this isn't what has happend, but if it is please feel free to learn from our mistake, just look in the pan for metal filings, if there is, you need a trany, and of course the correct flex plate. keep us posted. :)>-
denny.dikes
