Make some test runs 'round the block.., left & right turns 90deg. This, to be sure you have "following" steering.!an is there any other tip i should be aware of when towing
I love this place and have learned a lot from you guys who know more than me.If you are towing any distance though, I would disconnect the rear driveshaft. By distance I mean 200+ miles. Reason is that even though the vehicle is in neutral, the top gears aren't being lubed in the transfercase & can cause unprotected (oil lubrication) wear because the driveshaft will still be turning. Anything less mileage wise & you will be ok.
