Top Radiator Hose
notamechanic
After 4 years of light use (<6k miles/year on truck), the Gates hose drooped and wore through from the fan blades rubbing on it. It seems like the original hose was much more robust. But all I can find for a replacement is the Gates. 1. Is there a better hose? 2. Or is there a bigger issue here,that the fan protrudes aft of the cowling? A Ford dealer has a hose that is $66+. Yikes! Or is that the best solution?
1994 Bronco XLT 5.0 L w/ 144k miles. Thanks so much everyone!
Rons beast
Hey Not, welcome...
Install the Gates hose, but don't tighten it until you turn it a little at the thermostadt housing. (tourque it to move it a little higher away from the fan blades.)
My shroud had a small hole (1/8") in the top where there was a strap to hold the hose. I zip tied the hose to the shroud with a 3/4" thick wedge of foam rubber under the hose to help hold it up.
It's too dark for pics now. If you need them I will post some tomorrow.
Good Luck
RBuffordTJ
Norris, SC
One option is to go to electric fans on the radiator and then you have no worries with the mechanical one eating a hose and it also frees up some drag on the engine. Just an idea.
Bufford
DNBELOWBRONCO
CALIFORNIA
I have a 1/2" metal bar with one-sided stick foam on the ends to protect the rubber hose, mounted to the radiator support under the hose to keep it away from the fan belt! I have an electric fan but the belt is what put a small slice in the hose for me. I replaced it to be safe and keep it for a spare because it wasn't deep I just worry about those things. Your fan shouldn't stick up that much that it hits the hose. Has the shroud been replaced or is it cracked? Forget about using a 90 deg housing, tried that and the hose won't line up. So do like Ron said and twist it a little and yes if I wasn't a Motorcraft nut my next choice would be Gates too! >:) -Kevin-
N
notamechanic
Thank you Ron, RBufford, DNBELOW, and miesk5! I will put the Gates hose on. Christy
As to the fan being exposed...., it functions "best" with the blade being 1/2 inside & 1/2 outside the shroud opening.
That's the way it came fr. the factory.
Gates is good quality & USA made I believe. :D/
Many rad. hoses have that coil spring inside to help hold shape.
BobButtertone
