tires
Redneck86
First On Race Day
Colorado
my tires are pretty worn out but this what they look like on my truck.
Z
zach351
Cullman, Al
looks good on ur truck but ur right they look bald bout time to exchange i would say..
shift1313
VA
i think the wider rims really cut down on the overall height. here is mine
ive more pics just not uploaded and not on this computer.
here is the same truck, same rims on 32x11.50, the truck next to it is on 35s and all suspension lift.
Redneck86
First On Race Day
Colorado
Just so yall know that last pic was with the wheel cut and thats how much room i still have left between the tire and radius arms. And im thinkin also these tires might be a little smaller then 33", most the time the size is a little off. I should have more clearance when i put some Super Swamper TSLs on it, the actual diameter of those is 33.7.
shift1313
VA
zach, the 32x11.50s never did but the 33s i would have to say yes. i dont know for sure but id say the fronts under full compression with the wheel turned would hit the fender. if the rim was wider and the profile of the tire changed they would probably tuck but just barely.
this might be a little better angle
my truck has been off the road for a little while and i never took it on a trail with the 33s. it didnt rub under normal driving conditions.
WAK4LYFE
:mellow: hey people i just wanted to show that i stuffed 35 inch bfgs under my 84 bronco only problem is they rub on my radius arm but ill fix it easily by adjusting the *****..no lift tiresrims.jpg
figjeti
