tire stuffing...
badbronc87
im gettin a 3" body lift on my '92, i know most conservatives would say 33" all the way, and thats probably the way ill go, but is it possible for me to get a 34 under there, the actual size is gonna be 33 and change anyways, but for those with a 3 and 33s, how does that work for you? thanks-- tyler
muddog
Indianapolis, IN
i put a three inch body lift on a 01 2wd ranger. with a little cutting to the plastic bottom part of the bumper, (and taking off the front mud flaps) i was able to fit 35's with no problem. i now have a 93 fullsize bronco and at factory height I can fit 32's. If you put the kit on and take it down to a discount tires or someone like that the will usually test fit any tire as long as they think that you might buy them. good luck!
Wihill
