Autooracle
- Joined
- Aug 28, 2012
- Messages
- 2
- Reaction score
- 0
My 96 5.8 Bronco is just starting to leak from the timing chain. It just turned 100k miles. Water pump was replaced by a shop who was supposed to diagnose the coolant leak. They failed. Clearly it wasn't just the water pump leaking. Told me that coolant leaks can spring up after diagnosis and repair. The leak was never fixed! And the are trying to charge me twice to r&r the water pump to get to the timing belt. If anyone had labor times on replacing the timing chain gasket minus water pump labor I would appreciate it. Thank you for any suggestions on how to deal with this shop. I told them they will fix the timing chain cover leak and I will pay only the additional parts and labor to remove parts from the water pump to timing Chain cover leak.
