Thermostat
khouse
77 BRONC
Shreveport, La.
Just curious on whats the recommended thermostat on stock 77 302 2bbl 160,180 or a 190. Is running a higher temp or lower temp better. Mine is starting to run a little hotter going down the road and ideling. Going to change thermostat and flush out coolant. I dont see any leak around water pump so I'm hoping thats all it is.
Newer veh. req. hotter runn'n temps.
You (& we with older rigs) should be fine with 180deg.
1st, clean the sender & connection., then dry-mount, i.e. no teflon tape.
Take the old 'stat out & heat in a ***-o-water...watch to see if it functions.
Reason being., your heat issues may be in the rad. or worst case., the block.
Yes., a "flush kit" is "cheap" & gets the whole system , not just the rad.
Putting the chemical flush/cleaner in 1st. is also helpful.
Fan belt snug....don't go over 50% coolant as that can cause higher temps.
HTH
79' Buckin Bronco
