the bronco clunk
jakeman
I just bought a 94 bronco 5.0 It has a clunk when you firt hit the gas and let off the gas my mechanic said it was the tranfer case and someone else said that all bronco's over 100,000 miles has this clunk, any ideas would be greatly appreciated....Larry
J
jakeman
the U joints were checked, but i'm not sure what the other is does anyone have the same problem or is this something i have to live with?
ocalabronco
ocala, Fl
check the CD yokes at the t-case, as well as the ujoints. i had the clunk, then the yoke let go and took at the ujoint and dented both my mufflers from the shaft swinging around
If it sounds like a metal to metal slap, I go with Blade. Mine is doing the same and I finally found out that the holes in the rear radius arm brackets are egged.
My mechanic pointed it out to me when I asked him about the noise and my truck was up on his lift. You can't see it directly because of the bushings blocking the view, but what is visible is that the ends of the arms were not centered but were up toward the frame with the lift supports under the radius arms. Hope that makes sense.
Solution: new brackets, bushings and perhaps radius arms.
mbtech2003
cape cod, mass
mine had that klunk too.. rear driveshaft slip joint needed ****. and now several months later needs again. i'm thinking bout replacing.
So, as you can see Jakeman, there are a lot of Bronco clunks :)) Now all you have to do is find yours :( /emoticons/[email protected] 2x" width="20" height="20" /> . then let us know what it was :-B .
J
jakeman
how do I lubricate the slip joint the boot does not look like it is removable????thanks so much you have been very helpful guys..... [-o<
27770[/snapback]
If you are talking about the one on the rear drive shaft, there should be a grease fitting near the U-joint. The U-joint should also have a grease fitting. The on on the double carden joint behind the transfer case is difficult to get at and mine took a special fitting on the grease gun to do it.
gungho
I had a clunk on mine when you hit the gas and it ended up being a loose motor mount.
79brnco
