Hi Brodie.., welcome..!
Too much "antifreeze/coolant" will overheat an engine.
/emoticons/
[email protected] 2x" width="20" height="20" />
"...temperature gauge is running hot,"
I'm guessing you're meaning
reading hot..? (i.e. past normal)
---- because,
you say
"truck is not overheating"
How do you know this..?
The lazer temp reader fr. Harbor Freight is cheap & a good tester for engine temp.
As to usual issues;
The temp sending unit could be faulty.
Water pump
Dirty radiator (actual overheating)
Stuck thermostat (actual overheating)
Bad temp gage. (least likely)
