Tail Light and Cluster Fuse Blowing
laborrega
My 15 Amp tail light fuse and gauge illumination 5 amp are blowing all of a sudden.
They worked fine for about 2 months, and then they blew and i replaced them and they keep blowing.
Where should I start looking?
The brake lights work when pressing the brakes, it is the lights that turn on in the tail light when the head lamps are on that is not working.
Thanks guys!
tiller83
baton rouge
If your courtesy light fuse also is blown then it's probably the light switch,but it could also be a wire shorting to the body or frame or the voltage regulator for the alternator not operating,check for any exposed or burned wire.those systems are connected at the fuse block by a common(always hot)wire and at the light switch.GOOD LUCK.
JohnK
