t case swap
89Bronco58
Jersey
i have an 89 bronco xlt with the ******** **** button 4wd 1356 transfer case, well its going bye bye, will a manual 1356 transfer case bolt right in its place with no problems????
Yes it will bolt right in but youll need the shifter assembly . If you take up the floor mat or carpet you will find a cover over the factory hole in the floor where the shifter goes through so you dont even have to cut a hole just pull the screws out holding the cover in place . You will also need the factory shifter bezel to make it look right . :D /emoticons/[email protected] 2x" width="20" height="20" />
Ford644
