yo;
Check out our main sponsor here
http://broncograveyard.com/bronco/c-304
for posterity;
or
http://www.uspowertrain.com/axlesford.htm
If you get the Dana B.O.M.number; it can be determined exactly. see
http://77cj.littlekeylime.com/Dana44_3.htm
or, if Image doesn't load here, see:
http://www.therangerstation.com/tech_library/images/D60_id.jpg
See
AXLE GENERAL INFORMATION by Dana Spicer http://www2.dana.com/pdf/XGI.pdf Page 64 for Dimensions...
Axle Shaft Dimensions and Components
The front axle shaft listing is presented in numerical order by complete assembly number and contains
the component parts and dimensions for both outer and inner shaft ends and overall length.
Could be; 610267 FORD 44 FRONT 1987-88 BRONCO & F-150
610268 FORD 44 FRONT 1987-88 BRONCO & F-150
This is DANA's Catalog
Source: by Dana via Bill A (BillaVista);
See Page 30;
AXLE SHAFTS
Part # Description Ring Gear Diameter Overall Length 2/4WD # of Lugs Side; L/R Spline Count
Diameter Length WD Lugs L/R Count
FORD TRUCK
E3TZ4234A 87 & Up Van & Bronco 8.8 27-13/16” 2/4 5 RH 31
E3TZ4234B 83-92 Ranger 7.5” 26 1/4” 2/4 5 R 28
E3TZ4234C 83-92 Ranger/Bronco II 7.5” 29 1/8” 2/4 5 L 28
E4TZ4234A 83-91 Bronco II 7.5” 27 11/16” 4 5 R 28
MG1456 Aerostar 86-97 7.5” 32 1/4” 2/4 5 L 28
E3TZ4234D 83-86 Bronco, 83 F100, 83-6F150 8.8” 31 1/16” 2/4 5 R 31
E3TZ4234E 83-86 Bronco, 83 F100, 83-6F150 8.8” 33 3/16” 2/4 5 L 31
E7TZ4234A 87-96 F150/Bronco, 87-97 E150 8.8” 31 1/16” 2/4 5 R 31
E7TZ4234B 87-96 F150/Bronco 8.8” 33 3/16” 2/4 5 L 31
E7UZ4234E 87&up Van 8.8 35-9/16”” 5 L/R 31
D6TZ4234A 9” F150 & E150, 74-86 9” 31 27/32” 2/4 5 L/R 31
MG3000 66-75 Bronco Small Bearing 9” 27 1/4” 4 5 L 28
MG3001 66-75 Bronco Small Bearing 9” 29 5/8” 4 5 R 28
MG3010 66-75 Bronco Large Bearing 9” 26 15/16” 4 5 L 28
MG3011 66-75 Bronco Large Bearing 9” 29 5/16” 4 5 R 28
