yo, btw, No Qs here is da Zone are considered "dumb"
May be considered that in other Forums, but not here.
Again, BE SURE TO BLOCK THE TIRES, in Front and Back of each tire; I use cement landscaping blocks and used to use wheel chock wedges until someone "borrowed" them.
http://www.walmart.com/ip/Reese-Towpower-Wheel-Chock-Wedges-2pk/16880816
ONE SOURCE IS OUR SPONSOR here; Jeffs
they have -
Rear Springs, Stock (Pair)
Item #33251 - New
1980-96 Bronco, F150 4x4
4 Pack Leaf Spring
Pair
1389lb per spring
Restore that sagging rear end! No we're not talking about plastic surgery.
Brand new leaf springs for your 1980-96 Bronco!
These will bring the rear of your Bronco back to stock height.
1,389lb weight rating per spring.
http://broncograveyard.com/bronco/i-33251-rear-springs-stock-pair-.html'>http://broncograveyard.com/bronco/i-33251-rear-springs-stock-pair-.html
$205.00
Rear Springs, (Pair)
Item #33254 - New
1980-96 Ford F250
1980-98 Ford F350
6 Pack Leaf Spring
Pair
2,977lb per spring
4.25" arch
To be used with factory block applications
Brand new leaf springs for your 1980-96 F250 and 1980-98 F350
These will bring the rear of your F250 back to stock height.
NOTES:
These may also be used as extreme heavy duty springs for your Ford Bronco or Ford F150.
2,977lb weight rating per spring.
$299.00
http://broncograveyard.com/bronco/i-33254-rear-springs-stock-pair-.html
ASK for DISCOUNT;
Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
I have been trying to verify that Jeff is still offering this discount but no repsonses yet.
GL!
