regarrr
I took the Bronco out on some trails on Monday. I was out there for about an hour or so. When I finished up I couldn't get the 4X4 high to disengage. I've never had any trouble with it before. This time I tried going in reverse, then neutral and couldn't disengage the four wheel drive. Plain old neutral didn't work, and rolling forward in neutral didn't work either. I guess the linkage came undone sometime later because the shifter went totally slack and kinda just wobbles all over the place. So at this point I must've broken the linkage, but I wonder if there was something wrong with the transfer case too for it to not shift before the linkage gave out? or if the linkage was already worn enough to not shift? I didn't hit the transfer case on anything and the fluid level is good. Any help out there?
