Stock Manual Steering
aspring
The bronco is a stock 69.
I have quite a bit of play within the Bell Coupler. I can move it from side to side.
It makes my wheel vibrate back and forth at slow speeds.
I do not know what the shaft spline count is or dia.. It is a daily driver and Pwr Steering is a future upgrade.
What steering u-joint model from either BC Bronco/Graveyard variety would work without having to take anything apart?
Can I still drive the truck until I get one or is it unsafe with that amount of play?
All front-end steering components are new except for the box.
Thanks for the support.
Yah,
It could lead to a serious situation. TomsBroncoParts.com has those bell joints. (used) (I believe)
They're pretty simple....two metal blocks that sit on pins, a clip to hold them in, a washer/rubber seal, & some grease.
Drive like a "lil' ole lady" 'til you get it fixed.
The "bell" is designed to allow for frame flex.....a hard U-joint may cause binding out in the rough...especially climbing...I know this 1st. hand.
Bandit
BANDIT
Afton,Wyoming
I replaced the whole thing with a complete heavy duty Flaming River telescoping shaft,got rid of the rag shaft completely.It really firms up the road feel.
79' Buckin Bronco
