One more that I just recalled you can use;
Cruise Control Switch Installation on Aftermarket Steering Wheel in an 84
Source: by steveg (Steve)
http://www.supermotors.net/registry/10351/59211
For a while now I've been wanting to use an aftermarket steering wheel to replace the thin stock steering wheel in my 84 Bronco. But, I didn't want to loose my cruise control (the switches on the steering wheel). I remembered that older Saleen Mustangs had the OE switches mounted behind the steering wheel with a special bracket. Of course finding someone that was willing to part with the original Saleen part would be near impossible. Amazingly enough, though, I found a machinist (MARK) that has made new brackets that allow the use of stock Mustang switches just like the original Saleen brackets. The bracket is designed to be used with Momo/Sparco/any steering wheel with the 6-bolt pattern but I drilled 4 holes in it so I could put it all together with a borrowed cheapo Grant style steering wheel while I make sure it all works.
BTW: Most Ford cruise control switches are interchangeable (the resistance values) through 1996.
I figured I'm not the only one that has wanted to do this & thought I'd post the info. I'll post the guys email address later in case anyone is interested.
A new bracket: PIC #1
My bracket after I drilled it for the 5-bolt ****** PIC#2
Installed on my Bronco (excuse the ugly steering wheel, it's not staying):
A couple pics of the bracket installed on a Momo steering wheel:
I got a response from Mark. He said he'd be happy to make more. I believe they are $85 and the come with the mounting screws for the switches. You will need to supply your own switches, but those should be relatively easy to come by at a wrecking yard. If anyone needs help with the wiring let me know.
You can email Mark directly for more information on purchasing the bracket.
mardis91NO [email protected]
