steering stabilizer
mauser1111
i just installed a steering stabilizer on the front of my 95 bronco. I followed their directions the best i could and it seems to work alright, but my question is can the steering stabilzer hurt anything, i mean can it put uneeded pressure on the front end components or the power steering pump?
crazyhorse85
clarksville,tenn
NOT AT ALL,IT WILL ACTUALLY HELP YOR FRNT.END IF YOU HAVE LARGER TIRES...IT WILL HELP KEEP IT FROM WANDERING ON THE ROAD...I PUT A RANCHO ON THE FRONT OF MINE...ACTUALLY GAVE IT SOMETHING LIKE FIRM FEEL STEERING...AS LONG AS YOU INSTALLED IT CORRECTLY BY THE DIRECTIONS YOU SHOULDN'T HAVE ANY PROBLEMS...BESURE TO USE BLUE LOC-TITE CAUSE YOU MAY NEED TO TIGHTEN THE NUTS AFTER THE FRIST 150 MILES AND CHK PERIODICALLY FROM THERE ON...RED LOC-TITE IS PERMANET AND A PAIN TO TIGHTEN OR LOOSEN THE NUTS IF NEED BE...HOPE THIS KINDA EASES YOUR MIND ALITTLE.... B)
seansz28
