Starting problem, Need Help!!!
chris9074
Ok guys I need help, truck wasn't starting so I replaced celonoid, starter, battery, ran fine till I stopped at the gas station, then came out and she spins great but no spark, dragged it home, replaced coil, and entire distributor and ignition control module, and coil wires, now I'm getting no spark but can hear arcing and the battery is weak and draining fast, before I replaced the distributor I tried to read the check engine codes and it said vehicle not responding, now it's giving me code 35, one more thing when it was running the tachometer would jump to 3,000 and work from there, the rpms would be normal but the tach was acting crazy PLEASE HELP I GOING CRAZY
PS, check the battery and starter cables where the lugs attach to them.  If there is any corrosion replace it.  Also when you have a cable off clean both the lug and contacting surface with  something like emery cloth. Then when reattaching cover the area with a little silicon grease to give it a moisture barrier.
Elmomo
