Starting problem ignition or coil?
oregonred
I recently got my bronco running after sitting for 4 years. It has a 429 and started right up about a week ago. I turned it over about 20 times today and when I released the key to the ON position it started. From then on it will not fire in the start position, but everytime I release the key it attempts to fire. It is still turning over strong in the start position. Any ideas?
I will attempt to explain the issue in further detail. I have a 78 body on a 79 chassis. The engine is a 429 from a 67-69 thunderbird. I am running an edelbrock 650 carb. As far as I know, everything electrical is stock with the 78 body including the ignition. I disconnected the coil wire to check for spark. I am getting no spark when the engine is turning over with key in the START position. However when the key is released back to ON it fires once. If the engine catches upon release of the key, it runs no problem and I have driven it down the street without issue. The engine spins strong when trying to start, but I am getting no spark.
devo
st. louis, missouri
i dont know if you still have the problem, if you do here is what you do, these early style control modules had rubber gromments that plugged into the control module and what happens is the gromments get full of corrosion and limits the current flow down to pretty much nothing, so you cut and splice the wires together to delete the plug, problem gone truck runs and starts like it is suppose to, i know because i just did it to my 78 f150, it was doing the exact thing yours is doing and this is what i did to fix it
good luck
drubbz
