Starter?
Nates86Bronco
No one can seem to figure this out? I have an '86 Bronco 4x4 with a 351m. When I start the truck (cranking) there's an obnoxsious squeeling, whining, high pitch sound that what seems like to me is coming from the starter? I got the starter tested and it passed. Just not load tested. The teeth on both the starter and fly wheel look fine. What is this? The starter is new by the way? Oh and mind u that it does run and not make that noise. Could it be a bad starter under load? I don't wanna just buy a new one and have it not be it? It sounds like a dying animal when I start it! Any good suggestions or prior experiance?
Thanks
-Nate
Nate;
some info from Ford EVTM/PCED CD (service manual)
Unusual Starter Noise
Possible Source(s):
Starter motor.
Worn or damaged flywheel ring gear tooth damage or excessive ring gear runout.
Inoperative components.
C1 CHECK STARTER MOUNTING
Check that starter motor mounting is flushed (not cocked). Check that all connections are secure.
Refer to Removal and Installation for mounting information.
Check other necessary components related to the starting system to be securely mounted ignition
switch, distributor (12127), battery and transmission switches.
Check wiring connections for damage or shorting due to corrosion or stray wires.
Are the starting system components and wiring secure and undamaged?
Yes
GO to
N
Nates86Bronco
Hey thanks for the reply. It helps but I checked both starter and flywheel teeth already but looks normal. I was thinking it's an internal issue with the starter? Bendex, solenoid or something? It makes no noise during normal operation, can't be a bent flywheel?
rcarm74
