I just installed a Centech wiring harness in a 75 Bronco. I have a stock electronic ignition and using the ballast resistor. When I turn the key to start, the starter engages, but when I release the key to run, the starter does not stop. Even if I turn the key to off. It stops when I remove the battery cable. It doesn't start running (starter) when I reconnect the battery till I turn the key to start again.
Anyone have any ideas.? I have replaced the solenoid and the same results.
