starter/electrical problem
ryanapfel
Rancho cucamonga ca
When i went to start the truck the starter would stay on. Even after i turn off the truck it stays on. I took the cable off the starter solenoid to get it to turn off. Anytime i touch the wire back on the solenoid post the starter turns on. Got a new solenoid. Same issue. Even when the keys arnt in the truck. Any idea? Is the ignition in the truck sticking?
Rons beast
could be.....sounds more like the wires on the solenoid are not installed on the correct posts. Take a look at this post:91 Bronco Starter Solenoid Wiring, with photo.
Can't seem to paste the link, type "solenoid" in the search box, and look down the list about 3 to 5 posts.
The pic helps loads.
yo RYAN
Could be ign switch and/or the ign sw actuator
ign switch Troubleshooting in 87-91 (from Factory Manual and the Ford Electrical & Vacuum Troubleshooting Manual (EVTM); w/Wiring Diagram & Continuity Testing (Logic Tables); miesk5 Note, It is out of order, so read the 2nd from left page first
Source: by Broncobill78 (Dave) at Ford Bronco Zone Forums
http://broncozone.com/topic/14120-87-91-ignition-switch-info-troubleshooting-guide/
SEE MORE IGN Switch & Ignition Actuator Rod & TSB LINKs in my site @ http://www.broncolinks.com/index.php?index=225
Starter Relay pic in an 88 5.0
Source: by Jem270
btw Relay pic in an 89 5.8
Source: by Handy_andy_cv64 (Ed B)
BobButtertone
