Assuming that this is actually a Bronco, my first question is, are you sure this is a 460
? Bronco did not come stock with a 460, so if it is, it must have been installed later and I can't immagine someone swaping in a 460 and leaving and putting a 2 bbl on it. The 351 did come with either 2bbl or 4bbl and I wouldn't have either engine with a 2bbl, just my preference
/emoticons/wink@2x.png 2x" width="20" height="20" /> .
That being said, with a non computer controlled engine, Duraspark II, a couple of things that will cause that type of stalling are vacuum related and choke. If you let it come up to normal operating temp, will you be able to run in drive and reverse
Definately do a tune up. Then set the idle speeds. When at normal operating temp, disconnect and plug the distributor vacuum hose, put throtle on the highest cold idle step (rpm for this step should be approximately 2100 RPM), if not adjust the cold idle ***** to get that. Reconnect the distributor vacuum and set your curb idle ***** to approximately 1600. Fot on brake, put in drive, idle speed should be approx 650. If it starts to stall, put back in park and bump the curbe idle up a little. Repeat untill it idles in gear. Like Sweepersrgr8 said then add approx 50 rpm.
The choke either not opening or opening too soon will also give this type of problem. Assuming it is an automatic choke, check the position cold and then watch to see that it opens. It should be fully open with the engine warmed up. If it to comes off too soon it will give a similar problem. A lot of people go to manual choke to resolve this, but it can be adjusted properly with a bit of patience.
How about posting a picture of the engine. like they say, "A picture is worth a 1000 words".
