hoghappy
My ABS light has been on a long long time (5 years) and then my speedo started acting up this past winter(intermittantly not moving) while the tranny would shift in and out of neutral and shift hard...took it to the shop and they fixed the speedo and tranny by replacing the rear end speed sensor and said they could not get the ABS to work...a mess of codes and it would cost too much to start replacing sensors. So I drove it home 1/2 mile away, parked it and then started it back up the next day to move it in the driveway and it fixed itself. The ABS light is out and the brakes are working right again.
Is it possible the computer needed time to reset after replacing the sensor?
I'm just happy the tranny is not having to be replaced. 220+k miles and no smoke and not a drop of anything leaks anywhere....original motor, tranny and drive train even the water pump is still original...amazing. Did replace radiator recently and fuel tank, pump etc after she quit running this winter and I found rust in the tank. They sure were proud of that Motorcraft fuel pump... :angry:
