Smoking Brakes
Bic_David
quacksmeup
California
I have a 88 Bronco. I tow a 21ft fourwinns boat with it. It does allright on flat ground but comming down steep grades the front brakes start smoking and fading.
I'm looking into getting more pulling power such as gears etc. BUT I need to stop this thing lol. I have replaced all brake parts soooooooo any upgrades out there?
Yes I have oversized tires.
fbrown3
West Virginia
Might not be cheap, but try looking for a trailer with surge brakes on it if you don,t already have them (may be able to retro fit them). makes a major diff. when pulling heavy loads and may just save your backside some day.
Bic_David
quacksmeup
California
Ya thats true I have tandum axles with surge brakes. The boat anf trailer are 2002 models so everything is new also.
has anyone tryed vented rotors?
Shadow_D
Schenectady, NY
Go to your local auto parts store and get the extra heavy duty pads and shoes, they will me listed for "fleet vehicles" You may also want to upgrade the calipers and rotors for the same. As far as I can tell the "vented" cross drilled & slotted rotors may help some with heat dispersement but I have not tried them yet.
DragonDave
The OC SoCal
Wow! Smokin front brakes isn't a good thing......the next thing in line to happen would be to get em so hot they won't do much stoppin at all & depending on how steep the grade you are goin down,that might ****! Well the trailer brake thing is probably the best bet but probably not the most practical thing. Upgraded rotors, pads & maybe even calipers might help a bit. But in my opinion since your 1/2 ton brake system can only handle so much.......You should do like the diesels & throw it down a gear & take it ez!!!! ;) /emoticons/[email protected] 2x" width="20" height="20" /> My 2 cents Good Luck!
You might also look into rear brake disc conversion and the extreem duty brakes that are listed in Jeff's Bronco Graveyard "80 and above catalog.
Ktomek06
Definatly get a brake controller put in and get a trailer w/ some surge brakes
