smelly trans oil
weekendmechanic
which is it or is it both, I bought an 83 4x4 ford bronco with an automatic C6 transmission that just needed some touch ups here and there, and I have done some work on it it has a good motor except the transmission, it had bad pick up speed and, and little or no reverse, so I changed the motor oil and transmission oil and filter the transmission filter looked fine and so did the oil, and still no change so I replaced the modulator, and the oil that came out smelled burnt and was dark, and I had just changed it the day before, and now I'm told it could be a bad torque converter, any insites on what it might be.
Unfortunately by the time your tranny starts burning the fluid and acting up the damage has already been done. Even if it IS only a bad converter there's no fixing it without removing the tranny. Once you've gone thru the hassle of removing the tranny from a 25yr old truck you'd be a fool to not simply have it rebuilt. A bench rebuild for a C6 should run you maybe $750 or so, maybe less if you call around. I would simply rebuild/replace it and be done with it. there just aren't any quick fixes once it starts burning the fluid.
seansz28
