slow transmission leak
cheenyc
I have a slow transmission leak it looked like it was from the bellhouseing but got under and it seems to be more to the right by the passengers side when i looked up their is a small hose and it seems to be coming from the top fitting of that hose any one know what that is ? the hose seems fine and in good shape should i just take a screwdriver and tighten the fitting ?
Thanks guys
yo C,
the fittings the lines are screwed into are just screwed into the case using ¼" Pipe fitting. tighten it a bit; if it feels tight, you may need to take it out and apply some teflon tape to da fitting and ***** it back in the case, since its da top hose, there isn't any pressure when engine is off since t it goes to the cooler.
Also,
Parts Break-Out Diagram w/Major Component Nomenclature
Source: by lentechautomatics.com
http://www.lentechautomatics.com/images/aodcutaway.jpg
I relcall that for Mustangs, a Ford pal said there is a kit availbale to replace the fitting/hose clamps with a "newer" style. If the dealer parts folks can't help, check at local tranny shop. esp one where the Police/Fired dept and truckers take their vehices for service.
cheenyc
cheenyc
Thanks bro a little teflon tape made it nice and tight no more leak... Now i just need to take care of the oil leak from the bell housing ? some days its a drip some days its 30 drips ?
Good job!
I forgot to mention the bellhousing leak; since it's tranny fluid consider fromt pump.
And see if the Torque converter has a drain plug, which can be a cause if loose or a prev owner/"mechanic" X threaded it
Next up in da batting order is the dipstick O ring...look around there too; heat + age = a bad-bad o ring!
Other suff is possible incl. vent leak but only if tranny fluid is way overfilled & I doubt that is the prob since it's apparent you know da stuff.
GL!
Ford644
