Broncoholics
Broncoholics
I know it shouldn't be done but doesn't seem harmfull for a front shaft that doen't get ballanced anyway. Or at least mine never are.
Here's my situation: I need to shorten my front shaft 1" after adding a longer slip yoke.
I grinded off the weld on the tube (slip yoke end). I pulled the pressed in piece off and noticed the wall thickness of the tube was very thin like .095 or less. My thoughts are to replace it with .120 wall which I have. To do this I would need to take both ends and have them milled down to the ID of the .120 wall so they can be pressed back in. The tough part is keeping everything straight when pressing in the ends to reduct future vibrations. I have a chop saw that cuts very accurately. I can see this is the crucial part so it gets pressed on straight. Anything else?
