Shop Repair Manuals
Trinidadwho
West Hills, CA
Looking to buy the OEM Ford Service Shop Repair Manuals "1990 Ford F-150 250 350 Truck/Bronco/E​-Van Shop Service Repair Manual Book" any suggestions? Ebay has them but before I bid for would like to know if there are other sources. There is one that is on CD on Ebay, Im a little skeptical about that one just because it seems like a hassle to not have next to you while working or even problems navigating the manual. Anyone have the CD? Can I still drive up to the dealership and buy the manuals?
I don't have anything for a 1990 bronco, bu you can usually find them on eBay by searching, "Ford Bronco Shop Manual". Here are a couple of samples from that search http://www.ebay.com/itm/1990-Ford-F-150-250-350-Econoline-Bronco-Truck-Service-Shop-Repair-Manual-Set-/350600312675?pt=Motors_Manuals_Literature&hash=item51a1683763&vxp=mtr , http://www.ebay.com/itm/1990-Ford-F-150-250-350-Econoline-Bronco-Truck-Service-Shop-Repair-Manual-Set-/400306978120?pt=Motors_Manuals_Literature&hash=item5d3427bd48&vxp=mtr .
There are more but of the two I recommend the second set because it includes the EVTM. The price is right as an investment in your vehicle and having everything at hand. 1000 times better than a Chilton or Haynes which are Readers Digest versions of the real thing. When something is trimmed down like
Chilton and Haynes do, they leave out information that in their opinion you don't need.
yo T,
As the guys advised;
and for now, here are some Ford EVTM Wiring Diagrams in a 90
Source: by SeattleFSB (Seattle FSB) at http://www.supermotors.net/registry/20487/76450
That is what Ford will give; Chilton will give you a diagram that may be simialr but is usuallynot as accurate bec they use same diagram for multi-year applications.
Also, check w/local library to see if they have access to Mitchell OnDemand Online or All Data that has Ford's EVTM as its primary resource
Our library had Mitchell, but did not renew it this year due to $
Also, in my site; use internal Search feature for;
in a 90
Some results for Example are;
Cross-Over Tube, Diverter Valves & Hoses Location in Parts Break-Out Diagram in a 90 w/Ford part numbers
Source: by Ford via EzPc
For a Ford Vacuum Diagram (not including HVAC) get one for free on-line;
Look at the Vehicle Emission Control Information (VECI) Decal; Contains Vacuum Diagram & Calibration Parts List for 88 & UP. On-Line for Free at Ford. Click "Quick Guides" in left panel; Scroll to & CLICK VECI Labels "Provides Vehicle Emission Control Information (VECI) and a related calibration parts list." Enter applicable info (need to know your Calibration number from your B-pillar sticker). Vacuum Diagram is the same as the one on the core support or hood or air filter cover. Suggest Right Clicking this Hot Link & Open in New Window
Source: by Ford @ http://www.motorcraftservice.com/vdirs/retail/default.asp?pageid=&gutsid=&kevin=rules
T
Trinidadwho
West Hills, CA
Thanks Seabronc, I picked up the complete set from eBay. I offered the guy $140 and it was a deal. They came in a few days ago, they are awesome!
If you are wrenching, that is one of the best investments you could make in your truck.
guilhermeknob
