yo, I just bought Bilstein shock for my 96;
Their on-line catalog is ez to use and saw that for the the 4600 Series shocks (NO LIFT, Single shock set-up);
90 5.8 Bronco uses same front shock as a 90 F 250 5.8
I was surprised!
However; rear shocks are different part numbers
You can also verify by looking @ your 90's Door Jamb Label (Certification Label, also referred to as the Patent Plate, Data Plate & the Warranty Plate)
Door Jamb Label (Certification Label, also referred to as the Patent Plate, Data Plate & the Warranty Plate) pic in an 88
Source: by Jem270 at SuperMotors.net
look in lower right Under SPRING; B Z;
B (Coil) Z (Rear Leaf Spring)
And Ford does list diff spring in their MC On-Line Catalog @
http://www.fordparts.com/View Image
5310 Front Spring
Spring code C (Front)
5310 Front Spring
Spring code G (Front)
5310 Front Spring
Spring code U (Front)
5310 Front Spring
Spring code V (Front)
5310 Front Spring
Spring code B (Front) $214.60 Select a dealer for their prices and availability
5560 Rear Spring, Spring code Z (on page 5)
Then compare the F250 there for Codes
I'll post this for now
