Unfortunately, none of the Codes can be directly attributed to the shifting issues, exc that 411 can cause Hesitation During Acceleration
Key On Engine Running (KOER)
DTC 411 Idle speed system not controlling idle properly (generally idle too high); "...DTC 411 indicates a dirty/ bad or connector issue w/daIdle Air Control valve (IAC). inspect it for crapola. Some can be cleaned. But our's shouldn't since the TSB says; "...Cleaning is not required on sludge tolerant throttle body designs released for 1991 and newer model years...." in Idle Air Control (IAC) Sludge; Poor Idle TSB 91-25-07 for 85-92 Bronco & F Series & many others; "...Hard cold starts, hesitation and stalls on initial start-up or during idle or decel may be caused by sludge in the throttle body and/or idle by-pass valve. Sludge deposits or oil film on the throttle body bore and plate or the idle air by-pass valve may cause one or more of the following conditions. Hard Cold Start, Stall On Initial Start-Up, Stall During Idle, Stall During Decel, Rough Idle, Rolling Idle,
Hesitation During Acceleration. A new idle air by-pass service kit (F2PZ-9F939-A) is now available for service use to correct sludge contamination concerns of the throttle bore and plate only. It eliminates the need to clean the majority of past model throttle body applications. Cleaning is not required on sludge tolerant throttle body designs released for 1991 and newer model years..."
Source: by miesk5
see the TSB and a fix by NELBUR and more info in my site @
http://www.broncolinks.com/index.php?index=397
DTC 412 Cannot control RPM during KOER self-test high RPM check. "...indicates that during the Engine Running Self-Test (KOER), engine rpm could not be controlled within the Self-Test upper limit band. Possible causes: Open or shorted circuit. Throttle linkage binding. Improper idle airflow set. Idle Air Control (IAC) solenoid contamination. Items external to Idle Air Control system that could affect engine rpm. Damaged IAC solenoid. Damaged Powertrain Control Module (PCM). Turn the key \"OFF\", connect a tachometer. Then start the engine and disconnect the Idle Air Control (IAC) harness connector. Does the rpm drop or engine stall? If it does, turn the key \"OFF\" and disconnect the IAC. With an Digital Volt/Ohm Meter (DVOM) check the resistance of the IAC solenoid. It should be between 6.0 and 13.0 ohms. Due to diode in the solenoid, place the DVOM (+) lead on the VPWR pin and the (-) lead on the IAC pin. If it is not within specification, replace the IAC solenoid...\" miesk5 Note; Ford says the range is 7-13 ohms
Source: by Vincent C
Place your electrical meter on "Ohms" and touch the two spades on the IAC connector. The Solenoid has a Diode, so the DVOM Positive (+) probe must be toward the connector tab. You should have between 7 and 13 ohms. If you are outside of this range, replace the IAC
DTC 632 O/D Cancel switch, Overdrive cancel switch did not change state during KOER; is possibly the result of the test being done incorrectly. When you do a KOER test, you need to do a Dynamic Response Check is used to verify operation of the Throttle Position Sensor (TPS), Mass Air Flow (MAF), Manifold Absolute Pressure(MAP), and Knock Sensor (KS) during a brief wide open throttle condition. The famed "Goose test".
DTC 116 Engine coolant temp. higher or lower than expected Possible causes: Low coolant level (ECT), Ambient temperature below 10°C (50°F), Faulty harness connector, Faulty sensor
Testing; "..."But due to its simplicity of design, the ECT is rarely at fault when problems occur. Before testing the ECT or any other EFI component perform a self-test, trouble codes received during test can be used as a diagnostic tool along with other indicators. To test an ECT sensor you will need a volt meter. You can test the ECT by back probing the harness while reading the voltage returning to the EEC. Or you can removing the connector completely and test the resistance between the 2 pins on the ECT..." READ MORE
Source: by Ryan M (Fireguy50) at
http://oldfuelinjection.com/?p=28
Location pic; "...distributor cap is to the right and the throttle body is to the left..."
http://i54.photobucket.com/albums/g91/subford/Electrical/Distributor/TempSenderPBMOD.jpg
by Bill (subford)
TEMP SENDER is just for the Coolant Temp Gauge.
Source: by DABUCKIN at
ECT Testing, Voltage Chart @ Temperatures
