yo
As our friend, Seabronc advised, a yard $ is prob cheaper if they will pull it from a cluster or let you pull it; since we lost many yards here, the remainder are fussy about pulling small parts out of cluster or parting out a window from a door; they want the bigger $ for entire door.
91 ford bronco with a 5.0 - right? (someday fill in your profile or insert all applicable info in your Q because it does make it ezier for you to get a reply)
LMC
In LMC Catalog Page 36E4OD LMC Part # 49-6305 SHIFT INDICATOR ASSY 1 REQ $34.95 Each
AOD LMC Part # 49-6303 SHIFT INDICATOR ASSEMBLY 1 REQ $49.95 Each
C6 LMC Part # 49-6299 SHIFT INDICATOR ASSY 1 REQ $34.95 Each
btw, our SPONSOR here, Jeff's Bronco Graveyard does not carry it for any Ford after 79 for some reason
Some have patched that ind cable
http://jines.org/bronco/scaled.IMG_4692.JPG
Shift Indicator Cable Repair in an 84 C6; "...The plastic tubing that holds the gear indicator cable is broken in several places, starting at the point where it meets the indicator housing, which removes from the rest of the cluster with two screws. I ended up removing the cable entirely (which was broken as well) and replacing it with a thin piece of wire (from a CAT5 cable, actually) that is flexible but rigid enough to not bind. I still need to find a thin enough piece of plastic line to house it before I can reattach it to the shift arm, though..."
Source: by jkorbes
