Ideally., you would set the eng. to top-dead-center/on compression stroke prior to pulling dizzy...that way, it's on the "sweet-spot" already.If you've never located "T-D-C" on an eng. .... a good beginner way is to remove plugs so eng. will rotate easy.
Rotate eng. (clockwise fr. the front) by hand & with your thumb/finger over #1 cyl. plug hole., wait 'til you feel air push/puff past your finger. (might need a helper)
Then, move the timing mark right on the "0" mark (should be pretty close already)
Now you're ready to stab the dizzy.....a bit tricky as the rotor needs to point to #1 cyl. prong/plug-wire inside the dizzy cap when it drops completely down. (not just most of the way down)
There's an art to this., & a feel.....you can walk the rotor around several times as you pull the dizzy up & let it drop back down. eventually it will drop on the right spot.
Also., you can have someone wiggle the eng. rotation back & forth as you hold the rotor near the correct position. As the cam gear moves.., it may allow the teeth to mesh & dizzy to drop completely down.
Lightly lock it down & set timing with a light @ about 7 deg. advanced with vac. hose off.
Hope that's clear as mud....???
/emoticons/
[email protected] 2x" width="20" height="20" />
/emoticons/
