Rust
newguy
When I removed the fenders I found the outerside of both door pillars had rusted through. The parts catalog only show a 'Front Door Pillar' which I would call the inside piece and I'm talking about the other side that connects to the inner finder. I know that this spot is pretty common but do I have to replace the entire piece (both sides). Is it one piece? Is replacing the whole door pillar a big job, looks like it. Would it be an option to just grind out the rust (the drivers side is about a third of the way up) and have a piece fabracated to be spot welded in?
Thanks for the advice.
muladesigns1
Was Da Bronx now AZ
Join the club! I have a little bit of rust there as well, I had to cut the top ***** that jolds the upper fender off. If you wire wheel the area you can see the dimples from the spot welds you can drill them out with a spot weld removal drill bit. it will then give you total access to back of all the metal in that area. if you want a real good rust inhibitor try the por15. its like a liquid tar and stops rust in its tracks. ive used it on maby vehicles and have never had anything come back from rust in the area were it was applied.
bigbluebronc
ca
I am gonna have too say doors are there just too keep the mud sand and water off ya other wise your a restorer! Go wheel!!!!!!!!!!!!!!!!!!!!!!
