yo ERIC,
WELCOME,
Please post the year, and in future;
as soon in your profile, include your year, engine, trans, Xfer case & locking hub type (auto or manual) and any major mods such as body or suspension lift, etc. or in any question post. You'll get more accurate replies
Left Click your name in upper right corner; in pop-up left Click on My Profile
Below an Ad, in right side. Left Click Edit my Profile
In Left Side, Left Click Change Signature
for now;
What did you pull it a little? The Switch or wiring harness?
Wiring Diagram & Testing in 92-96; "...The only significant difference between '92-96 and '80-91 is that the MFS's DIMMER switch replaced the older beam select switch, but they perform the same function..."
by Steve
See the "To Test" block in lower right corner
Park Lamp Circuit
Test your old switch with that info if you still have it
Wiring Diagram in 87-89 Bronco & F series (Mitchell); MIESK5 Note, page 2 shows the 4.9 EEC and injectors, etc.; page 3 and on show 5.0 & 5.8; & 7.5 for F series
Source: by equivalent (Beetlejuice) at SuperMotors.net
