Hi folks - I am new to the forum. My son and I have a 69 Bronco that we've been fixing up over the last year. It has a 302 that until recently has been running great. We've replaced : distributor, plug wires, plugs, and coil. It is bored .030 over and we honed cylinders and installed rings and rod bearings - no issues with smoking or plug fouling.
So - suddenly it has developed a severe rough running condition - hard to start and will only run very rough at 1/2 throttle, will not idle.
Here is the weird part - yesterday I started it ( had to use starting fluid ) and it was doing its usual rough running - but then suddenly cleared up and ran perfectly for 2 minutes - then just as suddenly back to the rough running.
I has an almost new Holley 2 bbl that is getting fuel, pumps squirt and the fuel pump is pumping ( at least it squirts with the line off and engine cranked ).
At first I thought it might have 'jumped time' - but I checked the rotor position at TDC # 1 and it looks really close + if it has jumped time, how to explain the sudden smooth running for a brief period ?
Anyway - I am at a loss for what to try next. Any similar experiences or advice would be greatly appreciated !
Thanks, John
Thanks, John
