rough country lift
broncobros
i have a 1990 full size and i put a 6" in rough country suspension lift on it. i guess when the coils settled in the front, they settled a little much so now the front end sits about 3 inches lower than the back. what can i do to fix this?
yo BB,
WELCOME!
I've heard the same about Procomp's 6 inch springs.
Make sure front coil springs are positioned correctly in the upper spring seats
Item Part Number Description
1 N805348 Nut and Washer Assembly
2 18198 Insulator
3 5B315 Spring and Shock Bracket
4 5A333 Upper Retainer
5 40949 Bolt
6 18124 Front Shock Absorber
7 620468 Nut
8 620469 Nut
9 18126 Shock Bracket
10 805033 Bolt (Must Be Installed in Direction Shown)
11 3405 Radius Arm (RH)
12 3A292 Radius Arm (LH)
13 605921 Bolt
14 3002 Axle
15 58740 Bolt
16 3B446 Front Axle Radius Arm Bracket
17 40954 Bolt (2 Req'd)
18 390678 Stud
19 5B316 Lower Spring Seat
20 5414 Front Spring Insulator
21 5A349 Retainer
22 388833 Nut
23 5310 Front Coil Spring
A � Tighten to 34-46 Nm
(26-33 Lb-Ft)
B � Tighten to 18-24 Nm
(13-18 Lb-Ft)
C � Tighten to 34-46 Nm
(26-33 Lb-Ft)
D � Tighten to 60-81 Nm
(45-60 Lb-Ft)
E � Tighten to 364-440 Nm (269-325 Lb-Ft) Then Hand-Tighten to
434-461 Nm
(320-340 Lb-Ft)
F � Tighten to 26-34 Nm
(19-25 Lb-Ft)
G � Tighten to 258-311 Nm (190-230 Lb-Ft) Then Hand-Tighten to
326-352 Nm
(240-260 Lb-Ft)
H � Tighten to 94-134 Nm (70-100 Lb-Ft)
Take measurements and ask for replacement springs in warranty is still in effect.
Toll Free: 800-222-7023
They claim;
Lifetime Warranty
60 Day Guarantee
Did you get the new rear leaf springs or 3" lift blocks, add-a-leafs and u-bolts?
A kit lifts the rear by the use of blocks or add-a-leafs or a combination of those. A system completely replaces the rear leaf springs and offers both better flex and better reliability. Using blocks for lift can be dangerous off road because they can easily break or slip out causing damage to the vehicle. Replacement leaf springs are a much better way to lift the rear of your vehicle.
Adjustments in 80-96 Bronco; "...Side-to-side lean can be adjusted by about 3/8 in. (10mm) by installing a shim between the spring and axle on the low side. A Bronco that is low in the rear on both sides can be similarly raised by the insertion of 1 shim on each side. If the side-to-side lean is greater than 1/2 in., try switching the springs from one side to the other..." http://content.chiltonsonline.com/content/images/8492/images/84928050.pdf
BDS lift kits are top quality and have a NO questions asked warranty, if any part of the lift kit, skocks etc. breaks they will replace it for free.
GL!
Mgough
