rim size?
brad050
ok so I am looking to put 33s on my non lifted 84 full size bronco I have been told it can be dun w/o rubbing if you have the right size rims? what would be the best size rims to get? please give all specs B) Also is there any other ajustments that have to be made?
The bottom end for rim width on 33s is 8 inches. The wider the rim width the wider the profile of the tire. Can't guarantee that you will nor rub on a hard lock over turn though. Mine just started to rub with that size rim and 12.5s if I held it hard left or right. I have a 2" suspension lift on mine.
brad050
Um ok so what size are you saying is best? the smallest with rim I can get?
rcarm74
