snowman74
Alright ya'll...you've been so helpful, I'll ask another.
Got a little bit of rust problem at the bottom of the tailgate. As I understand it, this is common for older Broncos. The dang thing doesn't close up as tight as it used to anyway...and the electric motor is getting older. Should I just replace the tailgate with aftermarket? Is it possible to find OEM tailgate without sacrificing my monthly salary to obtain? How do I get it back to a tight fit? I'm sure the rubber needs replaced, but even so, It's still got just under a 1/4" play when it's shut. I'm thinking about replacing the spare swing as well. I've got the old style, and I like the ones like I've seen on the nineties models much better. they seem to lock up better too. Will that switch out without modification with my 87'? I can find a newer model swing arm at a local salvage for pretty cheap...or I could order from BGY.
Your input is ALWAYS appreciated!
