Replace bad 351m or go to a 400?
Garyp
My 351m has blow by a few pistons and valves and its all ready over 0.60, so looking at a short block and getting heads done.
I'm wondering why not just get a 400 instead.
Thanks for any advice.
Whipsaw
No replacement for displacement... still, you're looking at replacing all the parts that no longer bolt to the 5.8, what ever they are (PCM for one? or is it a carb?). Unless it's the same block and heads, I've not looked into it.
johnnyreb
West Virginia
Have you thoght about re-sleeving it? In case you want to keep it all original and keep the value up.
johnnyreb
West Virginia
Also some parts are balanced--that can,nt be inter changed with some motors.
blksn8k
PA
429/460 is also a fairly easy swap. Bolts up to the same tranny. I did a 460 swap in place of the original 351M on my cousin's '78 Bronco back in the early '80s. Should be even easier now with better motor mount and exhaust options.
johnnyreb
West Virginia
I put a 390 in one of my 78 bronco and didn,t have much problem. Mostly the exhaust on the drivers side. I put it the the one with the 4 speed transmission. I use the 390 bell housing too.
johnnyreb
West Virginia
I also had to cut some out of the towers where it sit down in.Not much.I think it has about a 3 inch clearance at the back of the motor.
ledzilla
Will Co, IL
The 400 and 351M are pretty much the same motor. Identical blocks. Only real difference is the crank, pistons, and carb calibration. They use the same connecting rods and everything else. My '78 LTD wagon has a 351M and I've been working towards rebuilding a 351M into a 400 and swapping it all out. The hard part is getting a crank. There are very few retailers with a new crank for a 351M/400, typically have to source from a junkyard and have it machined. Haven't seen much in the way of new connecting rods, either, but from what I've read the stock rods are strong and can take a lot of power (maybe 600hp). New pistons are easy to find, though. I do seem to recall there being one vendor out there with a 351M/400 stroker kit that has a full rotating assembly, but it was somewhere around $3K, I think.
johnnyreb
West Virginia
I think the rods are different too.
ledzilla
Will Co, IL
They are not. The difference in the 351M to the 400 is the stroke length which is managed entirely with the crank and the height of the pistons. The 351M has taller pistons to make up the difference with the shorter stroke, but the connecting rods are the same.
tony k
I swapped the 400M in my 79' Bronco for a 460 and have never looked back. More power, better fuel mileage, easy to work with. Literally almost a bolt in swap for me. I have had several upgrades over the years with ignition, fuel, starters, and now a transmission but swapping out the 400M with the 460 was the best decision I ever made.
Mi.Bronco
Michigan
I like the 460 swap idea myself. The 351/400m are like they said almost the same engine. Now a 351 Clevland would be a great choice it will bolt right up to the c6 and has much more power and all your accessories will bolt up. There is a great aftermarket for this engine and can be built to pull the world. Bit let’s be real a Coyote is the best choice for the money.
OJCooper97
