If the level is in the ADD section of the dipstick, then you should add oil.I just purchased a 76 that has a remote oil filter up inside the engine compartment. When i changed the oil and filter i put 5 quarts. the dipstick still showed a little below full should i have put 6 quarts in?
No, as Joe mentioned the best thing to do is to add *part* of a 6th quart and see if that does it. There are a lot of variables. The hoses will add some capacity to the system and so will a remote filter (as opposed to the internal tranny filter) it may be that you need a full 6th quart, maybe 6.5 or maybe only .5. You'll have to slowly add it in 1/4 or 1/2qt at a time until the dipstick indicates the tranny pan is at the correct level.I just purchased a 76 that has a remote oil filter up inside the engine compartment. When i changed the oil and filter i put 5 quarts. the dipstick still showed a little below full should i have put 6 quarts in?
it turned needing exactly 6 quarts, the filter is a spin on type from NAPA, it would cross over the a Motorcraft FL1A. Just had never run into to a remote style. Makes it a bit easier when changing the oil. Thanks for the helpNo, as Joe mentioned the best thing to do is to add *part* of a 6th quart and see if that does it. There are a lot of variables. The hoses will add some capacity to the system and so will a remote filter (as opposed to the internal tranny filter) it may be that you need a full 6th quart, maybe 6.5 or maybe only .5. You'll have to slowly add it in 1/4 or 1/2qt at a time until the dipstick indicates the tranny pan is at the correct level.
What type of filter does your have ? A duel filter arrangement will take even more. It's not hard to troubleshoot, just be patient and add it in aout 1/4qt at a time giving it a few minutes to settle out & remembering to ck it while hot.
