Yo Dale,
41, In Continuous Memory HEGO sensor circuit indicates system lean (right side).
In KOER No HEGO switching detected always lean (right side).
HO2S Failure, POSSIBLE LOCATIONS OF WIRING SHORTS TSB 95-02-11 for 92-95 Bronco & F Series; "the HO2S wires in the 12A690 (subassembly of the 14B060 battery cable) harness may be cut on the lower right engine mount causing improper signals to be sent to the PCM. Damage may be under the electrical tape..."
HO2S Failure Or Fuse \"E\" Inoperative, ABS Light On, Back-Up Lamps Inoperative, Daytime Running Lamp (DRL) Inoperative, MIL On, Inadvertent Self-Test, Speedometer Inoperative & Trailer Battery Charge Relay Inoperative in TSB 95-5-21 for 92-95 Bronco & F Series; "...the HO2S wires in the 12A690 (subassembly of the 14B060 battery cable) harness may become chafed and the vehicle could exhibit any one of the following conditions....Lack of proper HEGO operation may cause, or be the result of a rich or lean fuel condition, which could cause additional heat in the catalyst. Perform self test KOEO and KOER, service any codes. CHECK FOR PROPER HEGO GROUND G101.
Location in Engine Bay pics: G100 @ LH front of engine compartment on upper radiator support-in front of WS washer/Coolant overflow tank;
*** G101 front of fender apron-between starter relay & headlight***
; G200 behind RH kick panel; G103 (battery to engine) Lower RH front of engine; Same as Bronco in a 95 F Series
Source: by Ford via subford (Bill K) at
http://s54.photobucket.com/user/subford/library/Electrical/Grounds?sort=4&page=1
If the HEGO ground is good, the following areas may be at fault: ..." READ MORE @
http://www.supermotors.net/registry/media/747751
Source: by Ford
33, EGR valve opening not detected.
See my post,#2 @
http://broncozone.com/topic/24352-89-bronco-302-self-test-codes/
77, in KOER System failed to recognize brief WOT during Dynamic Response Test (user error).
74 Brake On/Off switch not actuated during KOER test (user error).
65 in KOER Overdrive OFF switch was not cycled during KOER test (user error).
96 Bronco-F-Series Workshop Manual (PARTIAL) by FORD via
http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
96 is same as most earlier years especially 90-96, except for:
OBD II in 96;
4WABS (93-96);
RABS (87-92);
Air Bag (94-96);
3 ***** Automatic Locking Hubs (Built from May 95 through 96); Spark Plug Wire Routing & Firing Order (The firing order for 1987-1993 5.0Ls is 1-5-4-2-6-3-7-8. The firing order for 1994- 96 5.0Ls & all 5.8Ls is 1-3-7-2-6-5-4-8.);
R134a in 94-96;
2-piece Spindle Rolling Diaphragm Seal (RDS) used on 5/95 to 96 Broncos & F Series 1/2-ton 4WD;
Mass Air Flow in 95 5.8 California models and in all 96s, other years used Manifold Absolute Pressure Sensor (MAP).
96 5.8 do not have the Air Injection (AIR), Secondary Air Injection; Pump (Smog Pump), Thermactor Air Bypass (TAB) & Thermactor Air Diverter (TAD) Solenoids; Diverter, Check & Bypass Valves, Cross-Over Tube, etc. But 96 5.0 does have the system.
The 96, Vapor Management Valve (VMV) replaces the canister purge valve (CanP valve) used in EEC IV.
Still researching other differences.
Section 07-01A: Transmission, Automatic, E4OD
http://www.diesel-dave.com/vehic/manual/stj/stj71a24.htm
"DIAGNOSIS AND TESTING
Diagnosis by Symptom
The Diagnosis by Symptom Charts give the service technician diagnostic information, direction and possible components, using a symptom as a starting point.
The Diagnosis by Symptom Charts are divided into two categories: Electrical Routines, indicated by 200 series numbers, and Hydraulic/Mechanical Routines, indicated by 300 series numbers. The Electrical Routines list the possible electrical components that could have caused or contribute to the symptom described. The Hydraulic/Mechanical Routines list the possible hydraulic or mechanical components that could cause or contribute to the symptom described.
Diagnosis by Symptom Chart Directions
Using the Diagnosis by Symptom Index, select the Symptom/Concern that best describes the condition.
Turn to the Routine indicated in the Diagnosis by Symptom Index.
Always begin diagnosis of a symptom by using the following:
Preliminary Inspections
Verification of Condition
Check the Fluid Level
Perform Other Test Procedures as directed
*** NOTE: Not all concerns and conditions with electrical components will set a diagnostic trouble code (DTC). Be aware that the components listed may still be the cause. Verify proper function of those components prior to proceeding to the Hydraulic/Mechanical Routine listed.***
THEN BEGIN with the Electrical Routine if indicated. Follow the reference or action required statements. Always perform the On-Board Diagnostic Tests as required. NEVER SKIP STEPS. Service as required. If the concern is still present after electrical diagnosis, then proceed to the Hydraulic/Mechanical Routine listed.
The Hydraulic/Mechanical Routines list possible hydraulic or mechanical components that could cause the concern. These components are listed in the removal sequence and by most likely cause. You must inspect all components listed to ensure proper repair."
Can you look through the symptoms and match up to your issues? I am using a tablet so it a and can't print, so my brain is swollen because I can't see your symptoms in Reply mode without screwing this reply up.
One thing I need to ask is, does the transmission shift from reverse directly to 2nd gear?
Can test the Transmission Range (TR) Sensor aka MLPS Manual Lever Position Sensor... it is a possibility.
Nagging Neutral Nonsense & Pinpoint Test, Manual Manual Lever Position (MLPS) also called Transmission Range (TR) Sensor. Some of the problems the MLPS can cause are wrong gear starts, TCC hunting, no 4th gear, engine stalling, high or erratic line pressure & a sudden neutral condition; The negative lead of the multimeter should be placed at the MLPS signal-return ground terminal at the MLPS...This sensor is responsible for more malfunctions than any other sensor in the sys- tem, and the kicker is that it seldom stores a code 67 or 634..." by Pete L
Test, Pin-Point in 92-96; from Ford EVTM; "...The negative lead of the multimeter should be placed at the MLPS signal-return ground terminal at the MLPS. Check the resistance of the MLPS: The resistance of the MLPS (pins 30 and 46).." read more
Source: by Ford via
http://ww2.justanswer.com/uploads/paynlessauto/2009-08-28_021637_222222.pdf
