Rear Window Key Switch (located on tailgate)
Brother Jukebox
I'm looking for a tailgate mounted key switch for the rear window. I just bought a 1988 full-size, Eddie Bauer, and mine is M.I.A.! I've searched several junkyard sites with no results. Also, I was wondering if I was typing the correct keywords. I'm not sure of the actual name of the part.
Apart from that , if anyone has ANY spare parts that will fit an '87-'91 full-size, Eddie Bauer, 5.0L 302, auto, please hit me up!
Thanks Y'all!
The switch itself is part of the window wire harness. If you are missing the the part that the key is inserted in, it is a key cylinder. I may have one hanging on my garage wall, if I do I'll let you know. You will probably need the cylinder plus the small hardware that attaches to the end of it. You might want to look at a local friendly auto parts re-cycler.
Brother Jukebox
Seabronc, you're a lifesaver, man!
I've been searching high & low for that thing. Even if you don't have one in your garage, at least now I know what I'm looking for.
Thanks a million, bro!
Andrew Sikes
