rear brake hose
stusainte
01085 Ma.
Hey everyone been a long time here goes 95 bronco found a rubber brake hose hanging under neith my truck The hose connects to the small junction box mounted to the rear axle hub themeatle brake line comes off the frame to a connector then to a rubber hose to the junction box then this hanging hose coms off the box and cant find where it connects to is this just a vent hose or should it connect to another line ?? any help would be appreciated thanks Stu
I'd like to see a picture of this. You should have a line from the junction block to each rear wheel brake cylinder, a flex line attached to the frame, (similar to the mounting of the front brake lines), then connected to the brake line which runs forward to the proportioning valve.
Elmo
Forsyth Georgia
I think the hose you are refering to is the rear axle vent hose. It should be secured to the frame by a small clip.
Dadpool
