Mudmagnet63
1971 Bronco the front signals work but I have no rear signals or brake lights. The fuse to signals/brake was corroded so I pulled it out and cleaned it up a bit and front signals started working.after futher investigation I found that the brake light switch on the brake pedal is not hooked up the tabs for spades are broken off ( new one on order ). I have several wires that are hanging free under the dash and have ordered a color coded wiring diagram for the 71 bronco. Any clues on which wires go to the brake switch and to the tail lights. I also found a switch ( toggle ) under the dash that I assume went to the spare fuel tank? any ideas???
