radio switch out
guitarfreek92
alright im attempting to replace my radio but i have a few question before i go and start taking things apart. how do i remove the atena from the stock??
the other wires seem fairly easy just that one seem sa little tricky? would i be better off taking it to a place that does them?
Cable Removal; "...before you pull the old antenna cable, tie a piece of string, twine, whatever to the end that plugs into the radio. Then pull the cable out. Now when you go to put the new one in, tie that same string to the same part of the new cable, then pull back through. It keeps you from having to fight the cable to go the direction you want/need it to go..."
Source: by UTfball
Cable Replacement, Radio in a 91; "...Remove the glove compartment and at the top back of that section you can find the antenna cable. Follow that back to the firewall. Ford put a hard metal "turn" and a grommet at the wall making it almost impossible to get out without a straight pull. Grab the cable at that point and once "popped" you can easily pull the remaining cable (and your replacement cable) throught the hole..."
Source: by Dagger_91Beast at Ford Bronco Zone Forums
Antenna Removal & Installation Parts Break-Out Diagram by Chilton
1.Remove the cowl top grille panel.
2.Remove the antenna mast from the base.
3.Outside, unsnap the cap from the antenna base.
4.Disconnect the antenna cable at the radio by pulling it straight out of the set.
5.Working under the instrument panel, disengage the cable from its retainers.
On some models, it may be necessary to remove the instrument panel pad to get at the cable. See Section 6.
6.Remove the 4 screws and lift off the antenna, pulling the cable with it, carefully.
7.Installation is the reverse of removal.
