I 've done the EFI swap on my 77 with a mustang moter. I decided to retain the power steering pump off of the mustang. I had a hard to time getting a pressure hose for the setup but i got one. Now after I hooked the hose up Fluid leaks out of the box where the fittings ***** in. Could this be because the mustang p/s pump pumps more than the original Bronco pump. Anyway what do you think my best bet is to fix the leak. Would alittle teflon tape work?
