challenger6pak
I am going to pull the transfer case and transmission out of my 67 Bronco. It is a 3 speed manual trans. It seems pretty straightforward but I am reading the factory service manual and there is a part that I don't understand. It says...
"Disconnect the shift rods from the shift levers, then place the first-reverse gear shift lever into the first gear position," OK i understand that then it says, "insert the fabricated tool (Fig. 2, Part 4). This tool will prevent the input shaft roller bearings from dropping into the transmission case when separating the transfer case from transmission and output shaft"
First of all, that figure two doesn't exist, at least I can't find it. What is this "fabricated tool" and where do I insert it???
any help is appreciated
matt
matt
