Pulled code 32 & 41
jimbronco91
Great Falls, Montana
Check Engine light came on so I checked for Codes & I got 32 & 41. I replaced the EGR & EGR Tube. When I was replacing the injectors pulling the intake the EGR Tube was stuck so I replaced both. I also got 41 Right bank but also I replaced the O2 sensor because I had to replace the catalytic converter. I am just at wits end. Please give me some insite.
Google says
Code 32EVP voltage below closed limit
Code 41HO2S circuit indicates system lean (right HO2S)
Code 41 can be caused by a vacuum leak.
Did you have these codes before you pulled the intake?
J
jimbronco91
No, I had to pull the intake to replace the injectors because someone sugared my gas tank & clogged the injectors so I had to replace them. I pulled shortly after when check engine light came on. I changed the EGR when I had it apart because I could not get the EGR pipe off the EGR.
J
jimbronco91
I have done so much work on the vehicle that I am not sure if 32 code showed up before I had replaced the EGR. I know the tube issue forced me to replace the EGR. I bought it as my vehicle to take to my cabin but I am afraid to take it up there with issues.
Good news is, neither one of those codes will typically leave you stranded somewhere.
How does it run otherwise?
I would probably start with vacuum leak checks, I use starting fluid and spray it around the intake when running. Some guys use brake cleaner.
Any exhaust leaks on the side with the O2 code? That can also cause the O2 reading to be off.
Hard starting when hot can be a fuel flow issues. Like a weak fuel pump.
A weak fuel pump can certainly cause a lean code.
Did you replace the pump and filter when you cleaned the fuel tank out?
I would imagine you will have to check the wiring next.
  • Unplug the harness connector.
  • First, check the signal voltage at the connector with the key on, engine off. Should be approximately 5.0v.
  • Then, check the resistance of the sensor cold. Should be between 58,750 to 40,500 ohms.
  • Plug in the harness connector and warm up the engine to normal operating temperature.
  • Then, unplug and check the resistance of the sensor hot. Should be 3,600 to 1,840 ohms.
mindy
