Hello the Programmable Speedometer Odometer Module PSOM is usually located behind the glovebox door if you open it then pull the stops in a little bit the door will fold down also how you get at the heater core box bolts . Unfortunately your truck doesnt have one they didnt start using this until 92 with the digital odometer . There is no speedometer cable on these it gets a signal from a speed sensor either on the rear end or on the T case or if you have an E4OD it comes from the tranny . What might be happening on yours is the EGR valve is sticking open this will make it run rough and idle low . Try that ./emoticons/biggrin@2x.png 2x" width="20" height="20" />
25016[/snapback]
